Displays the VLAN information portion of the circuit ID for the indicated VLAN.
| vlan_name | Specifies a VLAN name. |
| vlan_list | Specifies a VLAN list of IDs. |
N/A.
This command displays the VLAN information portion of the circuit ID for the indicated VLAN. When a VLAN is not specified, the circuit ID information for all the VLANs is displayed.
The following sample output displays circuit ID information for vlan "Mktg":
# show ip-security dhcp-snooping information-option circuit-id vlan-information vlan Mktg Vlan Circuit-ID vlan information string ---- ---------------------------------- Mktg DSLAM1 Note: The full Circuit ID string has the form <Vlan Info>-<Port ifIndex>.
The vlan_list variable was added in ExtremeXOS 16.1.
